CNC machine
TKS
Hi all,
i was wondering how you control a stepper motor...
in that way that you can control is speed...
i was thinking of a variable resistor...
conected to a PIC...
who measures the voltage etc...
but i don't know yet how to control the rpm of a stepper motor..
i also was searching for L297 examples
and should a pic 20Mhx (16F877a) be enough or should i go for a 18FXXX
then my last question...
is it easy for the pic.. to manage a serial eprom to be able to buffer data..
because large cnc progs maybe don't fit in the pic..
or should i give the pic his data realtime..????
TKS
TKS said:
Hi all,
All you do is control the frequency of the steps, there's a certain speed above which they won't move, anything below that is fine - a step a second, a step a minute - anything you like. Maximum speed is usually only about one revolution per second or so.
A 4MHz 16F877 would be plenty, or a 16F628 - there's nothing hard about driving a stepper motor.
Probably as well to send the data from the PC as needed, let the PIC handle what it's got then ask for more.
