coding a GOTO or BRA to??
Mr Deb I no the port pins don't match what your using If you re post what Circuit your using hopefully as a .png so we can look at all of it I think we can make this work and both learn from it. All this needs is the ports set right and it should work
The main code
Device = 18F1320
Clock = 8 // 8MHz clock
Config OSC = INTIO2, WDT = OFF, LVP = OFF
Include "Sound.bas"
include "IntOSC8"
Dim day As Boolean
Dim lite As PORTB.3
Function checkPIR()As Boolean
      If PORTB.4 =1 Then
        checkPIR = true
      Else checkPIR = false
      EndIf
End Function
While true
      If lite=1 Then
        day= true
      Else day = false
      EndIf
      If day = true Then
        Sound.PlaySound
      Else day = false
        checkPIR
      EndIf
      If checkPIR = true Then
        Sound.PlaySound
      EndIf
Wend
the Sound.bas module
Module Sound
Dim NOT_RBPU As INTCON2.7
Dim TMR1IE As PIE1.0
Dim TMR1IF As PIR1.0
Dim TMR1 As TMR1L.AsWord
Dim Speaker As PORTA.3
Dim SpeakerTris As TRISA.3
//global variables
Dim Seed As LongWord, Tone As Byte
Dim i As Byte
//half period delays = clock speed divided by 2*frequency
Const Tones(6) As Word = (2000000/12000,2000000/10000,2000000/8000,2000000/6000,2000000/4000,1000)
//interrupt routine
Interrupt MyInt()
    T1CON.0=0               //stop timer
    TMR1=-Tones(Tone)       //reset period
    T1CON.0=1               //restart timer
    If Tone=5 Then          //if silence
        Speaker=0           //speaker off
    Else                    //otherwise
        Toggle(Speaker)     //make sound
    EndIf
    TMR1IF=0                //clear interrupt flag
End Interrupt
Function Rand(Range As Byte) As Byte
Dim i As Byte, feed As Bit, temp As Word
    For i = 0 To 7                      //generate 8 bits
        Feed = Seed.30 Xor Seed.27      //make new bit
        Seed=Seed*2+Feed                //shift seed left and add new bit
    Next
    Temp=(Seed And 255) * Range         //change Rand from 0 to 255
    Rand = Temp/256                     //to 0 to (Range-1)
End Function
//main code starts here
Public Sub PlaySound()
NOT_RBPU=0              //WPUs on port B
ADCON1=$70              //all digital
T1CON = %10000001       //pre=1
Tone=5                  //no sound please
TMR1IE=1                //enable timer 1 interrupt
Enable(MyInt)           //set interrupt going
SpeakerTris=0           //Setup Port
Seed=$12345678          //seed random number
 While true
    If portb.0=0 Then       //if button 1 pressed
        For i = 1 To 10     //play 10 tones
            Tone=Rand(5)    //each tone is random frequency
            DelayMS(250)    //and for 0.25 seconds
        Next                //end for loop
    Else                    //otherwise
        Tone=5              //silence
        i=Rand(255)         //make rand more random
    EndIf                   //end if condition
 Wend
End Sub
End
Set the ports and she should be good to go.
Bert,
You definitely dont want a while true ... wend in a function as it will never return.
It should simply be,
    If PORTB.4 =1 Then
        checkPIR = true
    Else
        checkPIR = false
    EndIf
End Function
or,
    checkPIR = (PORTB.4=1)
End Function
Thanks Mike I changed it I see what your saying now. I was thinking there is even a better way to do this. Just do the switch checking at start of program and let it just jump over what switches are false and then play the sound. that way it will just keep rolling a long LOL
present circuit diagram in png
found a 3 terminal phototransistor for a better digital output but is it really needed?
need to conserve battery as well. can a SLEEP be implemented into code but cycling every 20 minutes??
Can a SLEEP be implemented into code but cycling every 20 minutes??
Yes I was wanting to see what switches it had with the phototransistor and all .
You may need two sound Functions so day it will play sound for 1 min and sleep 20 maybe. But in the assembly view it looked like it let me use the Sound module two times. Maybe Swordfish ideal of
you cannot make recursive subroutine or functions calls.
Not the same as mine LOL.
same or two seperate sound modules?
trying to decipher how to complie all the modules etc and see two different sound codes.
one has the dip switches and second one does not.
you mentioned that maybe I have to have two different codes?
one for day and one for night?
using a perf board and LEDs I have been programming a PIC and expereminting with the code to maybe learn what is going on.
learn by doing is my thing
What i was thinking is make a Sound module have two functions one for day and one for night. You can reuse a module. When you build it adds the code in so it still all inline. See what you need is to start at day if it's not day it will go to night that way your loop will keep checking "It's all about flow.
what is include "IntOSC8"
I think its a mistypo or ??
we have the sound module, timer module and need to include the PIR/daylight module I think?
this could be included (should be ) with the timer??
It's a module that set the osc so it will start full speed if you use module some time your osc will not start at full speed till all the module load and that can some times take a long time. if it not up to speed.
where is this module?
I looked in all of swordfish but never saw this file. I get an invalid file error.
I got the timer module as a module I think .
the error of invalid file for ocs8 comes up first.
had (a bad treminal) to fix my ribon cable.
the pickkit2 couldn't find it.
the ground pin didn't get soldered in the plug??
could have sworn I soldered all them pins.
I wonder if it would be easier to debug code using the con3 port on the junebug?(8 pin terminal) then just prg the junebug with desired code .
get it working then prg an off board chip.
presently I have a perf board w/ the 5 pin header w/ ribbon cable going to the junebug.have leds connected to pins 8,9,18,17.
should have bi colored leds so I could tell if a port is HIGH or LOW.
maybe order some on my next order.
maybe design a board so I can see what each port is doing.
the charlieplexing = I don't like. can't see what each indivual port is doing.
My next project that I am contemplating is a simple led candle flickering.
I have seen one where it just turns on and off 4 leds. I am thinking PWM.
but first this project.
coding a subroutine??
here is most of the code to date but I get an error trying to institute the routines like Playsound
how to do a subroutine. as I need to call Playsound, checkPIR
I tried a WHILE Playsound, IF Playsound THEN, FUNCTION etc??
// your main code would look like this
 Device = 18F1320
Dim day As Byte
Dim nite As Byte
Dim light As Byte
Dim checkPIR As Byte
Dim PlaySound As Byte
While true
      If day = light Then PlaySound
      ElseIf day = nite Then checkPIR
      EndIf
      If checkPIR = true Then PlaySound
      EndIf
//Wend
end
     // then just make three functions One for day and night
     // One for PlaySound
     // One for checkPIR
// PLAY SOUND ROUTINE
    // Device = 18F1320
//Clock = 8 // 8MHz clock
//Config OSC = INTIO2, WDT = OFF, LVP = OFF
while  Playsound then
Dim Speaker As PORTB.3
Dim SpeakerTris As TRISB.3
Dim Amp As PORTB.1 // turns on amp power
Dim AmpTris As TRISB.1//turns on amp pin 9
Dim Speed As Word
Dim dip1 As PORTA.0
Dim dip2 As PORTA.1
Dim dip3 As PORTA.2
Dim dip4 As PORTA.3
Dim dipRD As PORTB.0
//global variables
Dim i As Byte
Const Tones(18) As Word = (2000000/12000,2000000/10000,2000000/8000,2000000/6000,2000000/4000,1000,
2000000/12000,2000000/10000,2000000/8000,2000000/6000,2000000/4000,1000,2000000/12000,2000000/10000,2000000/8000,2000000/6000,2000000/4000,1000)
//interrupt routine
Interrupt MyInt()
Else //otherwise
EndIf
End Interrupt
Next
End Function
       OSCCON = $72            //select 8MHz internal clock
       ADCON1=$7f              //all digital
       TRISB.0=0               //make output
       PORTB.0=1 //makes pin 8 high for dip switches
       TRISA=%10111110         //A0 & 6 output
PORTA.7=1
While (true)
    Toggle(PORTA.0)
    DelayMS(200)
    Wend
End
        TRISA =%00001111          //sets your inputs on porta
While(TRUE) //repeat forever
    If dip1=1 Then //dip1 pin 1
       Speed=25
    EndIf
    If dip2=1 Then // dip 2 pin 2
       Speed=50
    EndIf
    If dip3=1 Then //dip3 pin 6
       Speed=75
    EndIf
    If dip4=1 Then //dip4 pin
       Speed=Rand(10)*15+15    //Speed = 25 to 250 random select speed
    EndIf
If PORTB.1=0 Then PlaySound //if night then PIR is enabled
For i = 1 To 200 //play 20 tones
DelayMS(Speed) //and for 1.00 seconds
Next //end for loop
Else //otherwise
     Tone=5 //silence
Wend //end of while loop
wend
 //CHECK FOR DAYLIGHT OR DARK
Device = 18f1320
Clock = 8
Include "Utils.bas"
Dim but As PORTB.0
Dim led As PORTA.0
SetAllDigital      //set digital so you can read RB0 or it will always read low
TRISA =%00000000  // if your using the junebug This is fool proof to get a led to lite
PORTA =%00000000  // Set's it all low
TRISB =%00000001  // Set's inputs and outputs
PORTB =%00000000   // Set's it all low
INTCON2.7=0        // sets wpu on portb turns on pullups on PORTB
OSCCON = $72            // 8 MHz clock
While true              // this loops it so it keeps checking
If day = nite Then checkPIR // enables PIR
    DelayMS(10)       // small debounce delay
ElseIf day = light Then Timer.Initialize  // triggers on timer
   led =1                 // Turns on led
EndIf                     // closes your IF THEN statements
Wend
End
//TIMER ROUTINE
// 18F1320@ 8MHz - they are just used here for clarity...
//Device = 18F1320
//Clock = 8
Include "ISRTimer.bas"
// constant ID to 4 * 16 bit timers...
Const
   Timer1 = 0,
   Timer4 = 3
// OnTimer1 event...
Event OnTimer1()
   Toggle(PORTB.2)//pin 8
End Event
// activate the timer module...
//Timer.Initialize
// initialise the timers - refresh every 1000Hz (1ms)...
Timer.Items(Timer1).Interval = 50        // 50ms
Timer.Items(Timer1).OnTimer = OnTimer1   // timer event handler
Timer.Items(Timer4).Interval = 200      // 2000ms, no event handler
// enable the timers...
Timer.Items(Timer1).Enabled = true
Timer.Items(Timer4).Enabled = true
// start processing all timers...
Timer.Start
// main program loop...
While true
   // this is a polled timer, not event driven - check to see
   // if it has timeout...
   If day = light Then Timer.Items(Timer4).Enabled
      Toggle(PORTB.2)//pin 17 trigger playsound
      DelayMS(10) //change state
   EndIf
Wend
I posted you some thing to go by even if your code runs it would take 10 to 20 min before the osc starts up your code flow is crazy
Every thing in red has to happen before it get's to the osc setting.
[COLOR="Red"]// your main code would look like this
 Device = 18F1320
Dim day As Byte
Dim nite As Byte
Dim light As Byte
While true
      EndIf
      EndIf
//Wend
end
     // One for checkPIR
    // Device = 18F1320
Dim Speed As Word
Dim dip1 As PORTA.0
Dim dip2 As PORTA.1
Dim dip3 As PORTA.2
Dim dip4 As PORTA.3
//global variables
Dim i As Byte
//interrupt routine
Interrupt MyInt()
Else //otherwise
EndIf
End Interrupt
Next
End Function
PORTA.7=1
While (true)
    Toggle(PORTA.0)
    DelayMS(200)
    Wend
End
       Speed=25
    EndIf
       Speed=50
    EndIf
       Speed=75
    EndIf
    EndIf
Next //end for loop
Else //otherwise
     Tone=5 //silence
wend
Device = 18f1320
Clock = 8
Include "Utils.bas"
Dim but As PORTB.0
Dim led As PORTA.0
Wend
End
//TIMER ROUTINE
//Device = 18F1320
//Clock = 8
Const
   Timer1 = 0,
   Timer4 = 3
Event OnTimer1()
End Event
//Timer.Initialize
Timer.Start
While true
   EndIf
Wend// your main code would look like this
 Device = 18F1320
Dim day As Byte
Dim nite As Byte
Dim light As Byte
While true
      EndIf
      EndIf
//Wend
end
     // One for checkPIR
    // Device = 18F1320
Dim Speed As Word
Dim dip1 As PORTA.0
Dim dip2 As PORTA.1
Dim dip3 As PORTA.2
Dim dip4 As PORTA.3
//global variables
Dim i As Byte
//interrupt routine
Interrupt MyInt()
Else //otherwise
EndIf
End Interrupt
Next
End Function
       OSCCON = $72            //select 8MHz internal clock[/COLOR]
PORTA.7=1
While (true)
    Toggle(PORTA.0)
    DelayMS(200)
    Wend
End
       Speed=25
    EndIf
       Speed=50
    EndIf
       Speed=75
    EndIf
    EndIf
Next //end for loop
Else //otherwise
     Tone=5 //silence
wend
Device = 18f1320
Clock = 8
Include "Utils.bas"
Dim but As PORTB.0
Dim led As PORTA.0
Wend
End
//TIMER ROUTINE
//Device = 18F1320
//Clock = 8
Const
   Timer1 = 0,
   Timer4 = 3
Event OnTimer1()
End Event
//Timer.Initialize
Timer.Start
While true
   EndIf
Wend
evey thing in red has to happen betfore it get's to the osc setting.
