woodlandman
I am planning to build a nine core pair eight magnet muller motor to drive a generator. they are all drive cores and will not be harvesting any excess power except to dump bemf back on main buss. i will be using square wire in the 14 to 18 awg range in bifiller wound set up around 72 to 100 volts. it will fire 81 times in one revolution so if my reserch is correct this magnet moter will be insanly powerfull .i have every thing lined up except i am confused about the drive circuit.it will be strickly dc no ac so i guess my question is should i use the high low driver set up or should i use just one single mos-fet to drive the coil pair ? this is for my own personal use and not commercial as muller has patent. please help me with any and all comments or suggestions. i thank you all !
