zevon8
Dont worry if the solder touches the tip of the iron, it often helps create a better heat transfer to the joint, since the tiny pool of solder will flow onto the joint, allowing more surface contact with the iron and the joint. What you need to do is get the tip to touch both the component lead and the pad at the same time, apply solder, let it flow, then remove the iron. On a typical small lead this all takes about 1 second or 2.
This is part of the previous link samcheetah gave, with pictures:
http://www.epemag.wimborne.co.uk/solderpix.htm
It's a very good tutorial, worth a read.
