Hi there,
first off, I am new to all of this. I am trying to build a little device that converts light of different colours into music. The idea is to have a light shine on a colour sensor that's placed in a dark tube and the light being interrupted rhythmically by rotors with translucent 'blades' in various colours. The light sensor should be connected to a circuit and depending on the colour that hits the sensor, should trigger one or more of an array of little 'oscillator circuits' (not quite, see below).
I can post a picture of the device in case my explanation didn't help.
Either way, the device isn't the problem. My problem ist that I have not found a way to make the colour sensor work. I have no history in electronics so my knowledge goes as far as the descriptions in the Nicholas Collins book 'Hardware Hacking' (http://www.nicolascollins.com/texts/originalhackingmanual.pdf, if you are not familiar with it).
I would like to trigger a circuit with the Hex Schmitt trigger chip 74C14 (as he describes in chapter 18) with this colour sensor diode:
not precisely a matter of choice, frankly because it is the only one I can buy here.
my question is thus, is it at all possible, and how?
I have tried to read the spec sheet good as I can, but honestly I have no clue what I am doing.
The way I put it together for myself is like this (see image), but it doesn't work, I thought maybe the diode doesn't output enough voltage to power the chip? Do I need a transistor? Do I need to wire it differently? Can I run a 9V battery through the colour sensor at all? Does it not react to light from a flashlight shone through a colour filter?
Any nudge in the right direction is much appreciated.
Many thanks!
Many thanks!
