I have been asked to design a CE amplifier with midband frequency=10k Hz, coupling capacitors C1=C2=10uF and Ce=100uF. A transitor with minimum gain B=100 is to be used. The CE must be using a NPN (2N3904 or eq) and I am supposed to find my RL=?Ohm,Av min=100,Zi=2.5KOhm,Zo=10KOhm, AC output voltage swing =3Vp-p max and Vcc=? [ Other parameters you may use to get started are: VE=1volt,IC=1mA,RE=1kOhm.These parameters are only guidence and must be change to suit the gain of your specific transistor.] [/b]
