Common Positive LED lights
rrekih
Hello
I am running common positive led lights RGB. They require the 12VDC to run on the negative (black) wire going to each light.
In turn when I ground out one of the RGB (wire) lights they light up.
I am using a common negative switch for doing so that I have run through relays.
I have negative wire going through the common of the relay so when it operates the rgb light has source to negative.
Is there a way to do this without the relays?
I'd much prefer the rising clamp terminals (first type) to those open screws! No stray unclamped strands as you tighten them, or self-cutting wires of you wrap too far with an open screw...
Just be sure to hold the terminal body as you tighten the screws. They look to be in short sections rather than a single long block, and with those the tightening force can twist the body against the PCB pins if you only hold the board.
I hear what you say about the rising clamp, just my experience in the past if open and closing a few times they sometimes don't open again.
