I have a simple circuit which is controlled by a comparator into an analogue multiplexer, i.e. when the input voltage at the comparator input is 'high' then the analogue multiplexer output one signal and when the input is 'low' the output is the alternative signal, all very simple.
However I need the output of the comparator to be a solid 0V, currently I am getting around 0.1V which is screwing up the analogue multiplexer. Is there anyway that I can ensure that that output of the comparator goes solidly to ground? I have a 10k pull-up on the output and I am using a LM6511 with single rail supply (I am not able get a negative supply on the board)
Thanks.
Thanks.
