ElectroMaster
Administrator
Competition #1: Most Imaginative Project
Welcome to the very first Competition on Electro Tech!
Sponsored by: BlueRoomElectronics.com - Supplier of PIC based microcontroller kits
Information
Using limited components you must build the most imaginative electronics project. You can use any number and type of interface components (for example LEDs, Relays, Switches, speakers, mics, etc.), however you are limited to maximum of 4 transistors, 10 resistors, and 6 capacitors. You must have a decent amount of text explaining your project, any schematics and also a photo of the completed project.
Judging
For this competition judging will be based on creativity and presentation. Both Moderators and Members have the chance to vote. Moderators (all 6) will each vote on their favorite project giving that project 1 point. Members will also be able to vote and the project with the most votes will be awarded 3 points, second 2 points and third 1 point. That makes a total of 12 points. The top three projects with the most points will win prizes. If there is a draw, the decider will be highest number of Member votes.
Prizes
1# $100 Voucher and a Junebug ( )
2# $50 Voucher
3# $25 Voucher
Entering the Competition
Entries can be submitted by email. Simply send your entry to electro.tech.online.com@gmail.com before 18th June 2008 (6 weeks from this post) and you will be entered into the competition. The subject of the email should be "Contest Entry For Electro Tech". Things to include in the email are:
Contact Information -Forum Username, Real name and Postal Address.
Documentation - Project Title, Project Overview, Theory of Operation, Bill of Materials, Comments/Notes.
Images - Schematics, PCB pictures, Finished Project.
Video - Do not send via email because of gmail limit, however mention it and we will work something out. Video is not required it is optional.
Please double check your work before sending it in. This is very important because you will be allow one revision only. That means if you send it in with mistakes and wish to correct them you only have one chance. This is to prevent to much work for publishing them on the site.
Good luck to all!
Note: Please do not debate the competition rules in this thread, if you want to comment on how competition work please use the forum. However, if you are unsure or do not understand a rule then it is okay to ask her.
Information
Judging
Prizes
2# $50 Voucher
3# $25 Voucher
Good luck to all!
