rubiks.cuber
Diodes
Diodes yes or no?
Diodes yes or no?
Diodes yes or no?
Yes
It does not matter what is inside a package when used as an interface component. It will be counted if it is not used as an interface component.
Be sure that interface devices are used as interfaces for your circuit.
It was used in late 1870s which helped to many scientists.After hearing this line I have to shift to another modern project.
So, wouldn't that mean it isn't your project idea, but just a copy of someone elses?![]()
Don't you still copy "ohms law" for your electronics projects?![]()
Yeah, that's what I thought too. The only way his analogy makes sense is if he builds off some idea from 1870 and improves it/uses it in a new way, then it may well be a valid and interesting contest entry.![]()
i'm deffinitely in! you can expect something more on the creative side then the electronics side though but i'll try to make it worth your while. one question though. are voltage regulators in any way prohibited?
Not sure what that is?hi
is that include the circuits with pic-micro
BR
my circuit uses 2 SCR's and 1 relay, the rest are the parts mentioned, can i use them?
Transistor type is vague. I am assuming that includes UJTs, phototransistors, opto-isolators and MOSFETs. The same may be true for resistors ( thermistors, photocells, potentiometers and sensors.
The power source is not counted as part of the circuit.
Does that answer your question?
