Dvt Dopesick
I have a bit of a snag that I must solve.
On my car, I am installing a Air Fuel Ratio Gauge. Now this gauge works on a 0-1 volt DC Signal. The A/F Guage I am install works on a 0-1 volt DC level. Unfortunatly the cars PCM Sends a 5 Volt Search Signal to the O2 Sensor at start up. If I hook the guage up to that it will definatly blow out the gauge at startup. However, that pulse is exactly that. A Pulse. I need to think up a way to stall the gauge from activating.
I was thinking a timer based 12v Circuit with a relay section to "null" the input going to the gauge. The unfortunate problem is, the signal wire going to the gauge CAN NOT be modifed or buffered in anyway. I thought of a timed "soft" turn on period. I will only need to create an "open" circuit of the input wire going to the device.
Also I was wondering, since it is a signal wire, should I place a diode on it to not send any transient or problem voltage from a circuit failure, back to the O2 sensor & PCM. I want to make a protection into the circuit if it goes over 3 volts it shuts down.
Keep in mind I am only going to "tap" into the circuit going from the O2 Sensor to the PCM, not interupt it.
I need to contact my source at dodge, about the 5 volt search signal, to find it's duration, and if any recurance of that signal while running.
I thought of the cap in parralell but I wish to build up more of a circuit so I have some sort of protection. The A/F Guage I bought was $65. I would wish to NEVER replace it for a over-volt problem caused by myself.
Also Vise-Versa with the PCM and O2 Sensor. I wish to make sure the circuit that meter will monitor, I want to make absolute sure the gauge if it fails, or circuit if it fails, has no way to back voltage the O2 to PCM circuit.
I thought of a zener, with a 3 volt cascade. perhaps someone could help me with that. I've never dealt with a circuit in this manner. The Timer and relay was the way I was leaning toward, but I still had to think of a manner of protection.
