Do yourself a favor and get a SN754410 H-Bridge chip or similar. They're cheap and easy to use, and made to do what you want. They have built-in snubber diodes so you won't fry your microcontroller.I plan to modify a toy cart with 2 small DC motors so that I can control the motors with a transistor connected to a microcontroller. Will this setup work, and do I need to add anything to protect the transistor from the motor.
By pulsed signal, you mean PWM? That works fine. No problem.Pulsed signal, through a H-bridge, what about remote control?
Yes you can, but you better really heat sink it good then!I believe you can also stack the IC futz recommended to increase current ratings. Buying on of these chips is a lot cheaper and easier than designing and building your own h-bridge (but not as fun)
