controlling hard disk motors using lpt
kariem2k
hello
i want to know how to control harddisk motor(after i ejected it from the harddisk) using the printer port to make it continuosly turns in a direction and the reverse direction.
also if you please tell me how to make a simple motor(not a stepper motor) to turn in a direction and reverse with two +ve sources from the printer port and one ground of the printer port(when i give it one +ve signal it turns in a direction when i give it the other +ve signal it turns in the other direction)
thanks
If you want to control a DC motor in two directions (forward and reverse) the usual method for doing so is with a H bridge. It requires only a +ve supply to work. There is tons of information on the web about it but if you can't find what you are looking for ask me and i'll give you some more info on it.
