Firstly, I didn't exactly know where to post my topic, so please move it if necessary.
I'm planning to build a kind of motorized panning and tilting head for a camcorder crane, and apart from the main construction, this is what I?ve planned this far:
The camera unit is supposed to be controlled by two servos (modified to "motors" if necessary (especially the panning unit)). I'm hopefully using a PIC16F84A micro controller to control the two servos, unless this makes the project (even) more complicated. My problem is to find a way to accomplish this project. Since my programming skills are somewhat limited, I need help to program the micro controller, making it possible to control the servos via some kind of input. I have a compiler for the PicBasic programming language, if it would help anybody. I have also a modified servo for continuous rotating available, and I can modify another if that would be preferable. I already have a circuit from a robot (featured in the book "Insectronics" by Karl Williams I hopefully can use instead of using money and time constructing a new circuit. However, if anyone has suggestions to a very low-cost, extremely simple circuit to make it possible for the micro controller to communicate with the servos, please let me know. Since I already have an applicable circuit, it would be great if anyone could se if they could help me programming the micro controller to make the servos respond to a certain input (e.g. a simple switch). If you know the language, you can use the .bas-files at the page mentioned above to help you understand the circuit. The perfect solution to my project would be some sort of input-controls (pot-meters?) that makes it possible to determine the amount of rotation / rotation speed on the (prospective modified) servos.
I hope someone understands this jumble. If you have any questions, please ask me. Thanks in advance!
