Menticol
Active Member
Hello everyone!
The objective of my project is to control the speed and inclination of a treadmill using an external micro controller, getting rid of the original control panel.
After watching a YouTube video where someone injected PWM signals directly into the board (of a similar make and model), I assumed that my OEM user panel worked similarly.
To investigate further, I created a small breakout board and started probing the connections with an oscilloscope.
To my dismay, what I observed on the oscilloscope made no sense. I identified two ground connections (G), a +3V line (S), and an +9V line (V). But on the connection labeled P, where I expected to see the control signal, there was indeed a signal, but with a frequency between 16 kHz and 20 kHz, that did not vary with the treadmill motor speed.
Any suggestions regarding how to interpret this carrier / proprietary signal will be very appreciated.
2025-01-15 EDIT:
Yes, ChatGpt is very useful, but its opinions must be taken with a grain of salt, or in this case, not taken at all.
First, I as convinced this was some kind of "proprietary protocol", when it is not. The unit is controlled by varying the duty cycle of a square wave. Simply changing the duty cycle provides full motor control.
Second, take all measurements where the control signal is generated (near the user control panel) and not near the motor controller board. The 20 kHz was just noise!!!
Best luck on your project, and avoid making my same newbie mistakes!
2025-01-15 EDIT:
