conversion from TTL (5v) to LVTTL (3.3v) with max3232 ??
ArixII
I am trying to read from a TTL board into a router that works on LVTTL (3.3v), with max3232. This TTL board is a motor controller called ssc-32.
I've first done these tests:
1. Connected TX of serial port of the router to TTL device directly, and issued commands, and all work fine.
2. I shorted TX and RX of the router to test if the port is working properly. I issued "echo hello" from TX and I had it right from RX back to the router. So this also worked fine.
Next, I used a schema I found online to connect them via max3232. I repeated the above test #1, but with the max3232 added in the middle, and it failed to work. I checked things more than 15 times, but no result. I'll provide a link to the schema I used here, please give some ideas to help! :)
http://www.lynxmotion.net/download/file.php?id=438
