Want to convert from 9v alkaline to solar rechargeable
Ken1
I have 2 ultrasonic pest repellers to control pests from feeding on my garden. They are both powered by 9v alkaline batteries. I would like to know if it is economically feasible to convert them to 9v rechargeable batteries with solar panels mounted on or next to the units to automatically recharge the batteries. If so, what components do I need?
Just a voltage regulator with a series diode at the output to the battery. The solar cell maximum current will act as a current limiter.
For NiMH, use six cells and set the voltage at full charge to around 8.7 - 9V
For lithium, you would need a two cell combined protection and balance module connected between the cells and everything else. Do not use internally protected cells with those.
Use a solar cell panel just big enough to prevent the device shutting off from low voltage; with a simple system like this, the batteries should occasionally reach full charge, but not be held there continuously. Setting it up so the cells partly discharge frequently will give the longest cell life.
(Ideally, they should charge with current monitoring to100%, then the charge shut off until they are down to around 20%, then charge again. Using pest control melbourne a barely large enough cell should allow some cycling and avoid them being held at full charge, which can wreck them quickly).
NiMH are really better for a minimal system such as this. They can be held at full charge just about forever, as long as the voltage is not too high.
If you "open" a 9V battery, you'll actually find six small batteries inside.
Some "ultrasonic" pest repellers do not produce ultrasonics because they are fake and since buyers cannot hear ultrasonics then they do not know they are fake and without any ultrasonics.
Can pests hear ultrasonics and if they do hear it are they repelled by it? Maybe not.
What pest are you trying to prevent from feeding on your garden?
