rasterburn
Hello, I am working on a small project and I will be needing to go to the local electronics shop to pickup some parts for it, but I thought i might ask on here first which I will need.
I am converting an ATX computer powersupply to run as a bench power supply, I want to be able to utilize all the available rails supplied by the power supply. the color coding and the pinout of the wires leading off the PSU have already been marked and labeled in accordance to their voltage output but I will need to pickup resistors for the rails to provide the minimum operating load. I understand that not all computer power supplies require this load but its better to be safe then sorry![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So the psu I will be using is rated at 250w
+12v = 14A
+5v = 25A
+3.3v = 18A
-12v = 0.8A
+5vsb = 2A
so far the only thing i have really done is cut the ends off the wires and wire in the power switch but I am not sure what resistors I need to purchase to provide the required load for +12v, +5v, & +3.3v.
I read on another site that 1A for the +12v, 0.3A for the +5v and 0.5A for the +3.3v was sufficient for proper operation, does anyone have any confirmation of this? or does someone know a more exact number?
+12v = 14A
+5v = 25A
+3.3v = 18A
-12v = 0.8A
+5vsb = 2A
