If you want to focus on Grammar and spelling then honestly I am not the person your looking for.
Hi T,He's from the UK which we all know is not a place well known for having superior proficiency in and of the global English language by any means.
Also being both our spoken and written languages are adaptive living languages regional and even local sub dialects, grammar and whatnot adds sub layer variants to things that can make two or more ways of saying something correct even if they are in formal contexts contradictory to one another when viewed from the opposing local standards.
I know my northern midwest ways of saying some things is different than how someone from the deep south US says the same implied points. Both are correct in local contexts even if neither reads exactly right and proper by classic formal standards.
Rather why grammar naziing anyone almost always fail and immediately collapses in on itself over some simple oversight.![]()
Ok i think we have crossed wires.Hi T,
Thanks for the enlightenment, I assume you are referring to me, I have slight dyslexia so reading is sometimes quite an effort, if I don't know the meaning of something.
C.
Yours was the only one with merit, LG.... Energy output is good but is it good enough? ...
Power your alternator directly from your motor. you'll have less loss than sending the power to the water for motion then extracting it again. Just extract at the shaft.
Whats wrong with the current place the alternator on a boat is?Using a turbine to harvest energy while using your motor to push through water? Do this instead:
I think the OP is on about charging while under sail, in that case it dosnt matter where on the engine you put your alternator! Your not getting anything out of it. If you got a aluminum boat and can get some speed up with it, i have a way you can make alot of free electric!! But you have to not mind holes appearing in the hull after a while
My calculations worked out that 15hp will be sufficient. If current units can produce 1hp with barely noticeable drag, surely I can get to 8-10hp?
To be clear, I want to produce the power while using the motor. If I can sail (conditions favorable) I don't need more than my existing power reserve and I intend to sail as much as possible, that's what I love and look forward too. Most offshore sailors recommend that you should be able to steam/motor for 1,000nm, best case scenario.
Doesn't need to be a quantitative example. Same motor, same alternator; his example has additional features for loss: prop to water, water to turbine.Show us the numbers behind that setup including efficiency losses relating to both the motor, 20KW, and the alternator, 2 KW, assuming a 95% efficiency for both.
Now i am confused.....This is what convinced me he wants to recharge batteries by putting a turbine in the water, extracting energy from motion. motion created by a motor taking energy from those same batteries.
