Late Summer, my compact tractor (Case DX40) coolant temperature gauge started to read high. The Case DX40 is almost identical to the New Holland TC40DA. I posted on a tractor forum and got some very useful information shown below. The gauge is a Stewart-Warner and is apparently what it calls a "bi-torque" gauge.
The gauge read well into the red zone after only about 10 minutes of running. Replaced thermostat and sensor. Both items tested OK on the bench afterwards. Gauge pegs high, as expected, when sensor wire is grounded. Now, the advice is to replace the gauge, but I am wondering whether there might be other causes. I hate swapping parts blindly and throwing good money after bad until the problem is resolved. That can get expensive. The gauge is a little over $100.
Here is the circuit for the gauge (from TractorByNet):
And here is what the inside of the gauge looks like (same source):
All of the resistance measurements on my gauge are within specifications, but apparently, a bad gauge can act like that. The S-W troubleshooting chart lists a defective voltage regulator and improper grounding as additional causes to investigate. I have checked the grounding at the alternator. Next project will be to test the alternator output at the battery (NB: battery seems to charge normally and has not lost electrolyte).
I am after suggestions for what to do, if the alternator voltage is within limits.
1) What would you accept as the absolute highest acceptable voltage at the battery? 13.8V, 14V, or ???
2) Would you advise any other tests, like with a scope to look for bad diodes?
3) Does anyone know whether additional voltage regulation is usually built into the instrument cluster? Getting to the PCB for the cluster is doable, but will be a pain. If the alternator voltage is OK, then my next steps will be to built a 12-V powered circuit on the bench to test the gauge.
4) If the alternator voltage is high, what is the likelihood the regulator be repaired at home? I believe the regulator is separate from the alternator on my tractor. Both are quite expensive.
Thanks in advance.
John
![Circuit_Capture.PNG Circuit_Capture.PNG](https://www.electro-tech-online.com/data/attachments/70/70991-40f7217b31b71c5bd3e73bc0949a71f5.jpg)
![Innards_Capture.PNG Innards_Capture.PNG](https://www.electro-tech-online.com/data/attachments/70/70992-d12bad8a73081aaaaa0408e703110570.jpg)
Thanks in advance.
John
