Creating enclosure for electronic appliance
treviko
I'm going to create electronic enclosure for custom project, two small PCBs mounted in one case. Design for 3D Printing.
Large PCB have 4 mounting holes, small PCB 2 holes. I'm not sure how to properly to attach PCBs inside enclosure. Should these holes be used to screw the PCB to bottom base with self-tapping screws, or for positioning the PCB using round pins something like this? Tne PCBs are thin (1.3mm), and I'm worried that the PCB does not bend when use self-tapping screws. Another point is, how to attach together top and bottom parts of enclosure?
I use threaded stand-offs with suitable screws on top and bottom end of the stand offs.
You can also get plastic clip-ins that have no threads.
Max.
hi
Take a look at the enclosures offered from Hammond. Some of them already have mounting standoffs for a PCB and are low cost. It’s best, however, to take the enclosure form factor into account before designing the PCB.
eT
This kinda thing:
If you are 3D printing, use the advantages of 3D printing...
Use captive nuts. Super easy - I highly recommend.
Good assortment. But in my case I have to use custom made enclosure,as I have pre-made PCB (mount two PCBs in one enclosure).
It should not be hard to use this box as a starting place. Make it bigger. Put a screw in every corner. Add standoffs to match your two boards.
Here is a idea. Put one board in the box and the other on the lid.
