bculver
Hi Everyone,
I need help trying to find a solution to my robot motor. I purchased a R/C Hummer from Walmart and happily started converting it to a robot with .... some purpose, not sure what yet. Nonetheless, after careful observation I learned the following:
The battery it came with says Nikko Ni-Cd 6V 650mAh
It has a **broken link removed**
and a simple motor in the front (I know nothing about it).
I want to use this diagram ... and yes
, I have all the parts (why I still want to build it), but after reading all the motor controller related discussions in the forums I feel I need to expand the circuit to read the current and cut it off. I am using an OOPIC to drive this robot. Here is a link to my **broken link removed**
Once I am done building the entire thing, it will operate 8 LEDs, a Polaroid 3500 Sonar, 4 IR Sensors, 1 LDR,and 2 Motors. In the future, I may add more to it, to give it purpose and better control it. I am positive this Hummer will be running into things and it worries me that I will burn out the circuits. I thought about a current-limiting resistor but I have no idea :shock: how to implement that ... actually the current sensing is above me too. I am completely new to this with just LED projects behind me so far.
Also, originally I built this thinking I could use it, but then I realized it outputs 12V where I need 6V. PWM Motor Driver with LM18200
I need to figure out how to wire the front and rear motors ... I think the front motor might be a 3V motor ... and its just for turn so its always going to stall ... I'm lost!
Any advice, help in any way is truly appreciated on my part. Thank you in advance.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
