killivolt said:Do they make a refrigerated heat exchanger that mounts in a similar fashion. I'm guessing this was nearest the cpu ?
............... kv
blueroomelectronics said:I think this much work for a few MHz is much ado about nothing. As much as I enjoy tweaking I've never been bitten by the watercooling bug. I suppose it was fun in the early Pentium days as a MHz meant something. Now your videocard does much of the work and CPU speed is less important.
And using the wrong coolant will eat your aluminum stuff.
I Don't have any aluminum in the system XD. BTW, what the hell is that in the picture ? looks like some hobo version of a water block... I wouldn't be surprised if that block leaked XD..
Frosty_47 said:t3h cPeeU evaps & ph4s3 ch4ng3 H4RdWer kan be bught h3re:
I think yur teeth ur chatterun boy go inside and get warm.
kv
3v0 said:If you are into cooling you should be interested in
how warm the CPUs are. Two utilities to measure CPU temp
Speedfan
https://www.almico.com/speedfan.php
CoreTemp
https://www.alcpu.com/CoreTemp/
Speedfan has been around for a while and has many features.
CoreTemp is rather new but reports the temp for all cores.
You mean /r/-tard?Krumlink said:Bill:Yeah, haha what a arftard...
killivolt said:Ever had some freeze spray ?![]()
killivolt said:Try this if you get a chance wet down a fly then freeze - 'em. Later pull him out and cover him with salt watch what happen's.![]()
Not with you.Frosty_47 said:BTW, do u play CS ??
killivolt said:That's ok! he'll just starve. Two brain cells don't provide much nourishment.![]()
