Thanks for the suggestion, but did you read my initial post?Peter_wadley said:I just use plain old tin snipes.. works fine!
Thanks, that sounds like a good option, but it will be a bit expensive for one PCB.Shax said:Don't mess about with anything that will create dust.... Get an electric water cooled Diamond tile saw. I have a Plasplugs saw that I bought 7 years ago. Cuts PERFECT straight edges with ZERO dust. The latest version retails at £29.95 (UK)..
ljcox said:I would certainly prefer to use a guillotine if I had one. But I don't know if I can justify the cost just to cut a few PCBs. However, I'll find out how much they cost before making a final decision.
Thanks for the comments.
ljcox said:Have you tried cutting a large PCB on it, mine is 300 x 300 mm (about 11 3/4 inches)?
Ues I have used a wood blade designed for cabinetry. The blade cuts wood so smooth that very little sanding is needed. I have been able to cut boards as small as 1" wide, with care of course. I always ran the PCB thru slow and with great care. I have been using the same blade to cut plexiglass(a trade name for plastic) I have been using red and green for lenses for LED displays. I leave the paper on, cut it slow and then strip of the paper. Here again some of my lenses are abourt 1" wide.ljcox said:That sounds like a good idea. I could then cut it on the Triton.
Do you mean that you used a carbide tipped wood saw blade? Or some other type of blade?
I took a photo of the Triton in the Jigsaw/Router mode but without the Jigsaw or router mounted.
For anyone that is interested & has not seen a Triton, I also took photos of it in some of its other modes.
Photo 2 shows the bench saw mode.
Photo 3 shows the cross cut saw mode, but I oriented the saw incorrectly. It should have been turned 180 degrees.
Photo 4 shows the planer mode.
It has adjustable mounting plates for a variety of comercially available power tools.
There is also an extension table that can be set up for sawing large sheets of chipboard, plywood, etc. but I need the car out of the garage to set it up.
It only takes 2 ~ 3 minutes to change modes.
There is also a vacuum dust extractor available - it uses a standard vacuum cleaner.
EDIT. I've had problems attaching the photos - I'll try again later.
Mike,mike11298 said:Errr i use a hacksaw and a fair bit of dust is produced... how bad is that? should i just grab a cheap respiration mask? I wanst sure if this is going to give me lung cancer when im 30
