Does it say AC output on it?2amp wall adapter wont run the fan at all WTF?
Now that's really weird... o.0. Is the barrel connector polarity the same as your other one? Sometimes the outside is negative and the inside is positive and other times it's the opposite. Measure the voltage with your meter.in :100-240VAC 50/60hz .55A
out: 12vcd 2A
Try it with the batteries again to see if the fan still works. Reverse polarity can damage the motor (well not the motor so much as the electronics in the fan). Try the flick startup too.I tried even just sticking the wires directly to the adapter with both polarities
The fan motor still works
I cant get to the connections on the motor
Just hooked it up to a 12v car plug with 5a fuse and worked fine
That's fine. I just need the connections on the connector between the fan and wall adapter, not the motor on the actual fan. You're saying that it says 12VDC at the moment you plug the fan in without any other momentary value?I can get at the connections and it is saying 12V but i would like to get at the connections at the back of the motor but cant, its built into the metal casing.
Why wont it work on the wall wart Max?
If I run the Multi meter inline I get like 300mV
