These days, there are many inverter modules such as this -
https://www.electro-tech-online.com/custompdfs/2013/01/FNB41560B2.pdf
This Fairchild datasheet and other similar products claim that their intended application is small power consumer motor drives like washing machines and ACs.
What I'm curious about is how the DC bus would be generated in such a system? Is it just a diode bridge? Would the DC bus have to be isolated from the household 120VAC?
The reason I started thinking about isolated DC is because I'm assuming the digital ground (the buttons, keypad interface and other UI) would have to be chassis (earth) grounded at some point. In the case of these modules, the digital ground and the dc-bus negative are electrically not isolated. Wouldn't it be a NEC violation to ground the DC-bus negative?
Thanks!
Thanks!
