Connect a reverse-biased diode, rated for at least 3A, across the motor (which has considerable inductance, so is likely generating voltage spikes and causing the drop-out effect you are experiencing).how can I add this?
Can I just put this diode across the entire load?across the motor
The sewing machine motor (possibly with snubber components) is the intended load, as I understand it. Rload in my circuit is just for simulation purposes.Can I just put this diode across the entire load?
Which one (I've posted three, but it looks like you are using the first one)?That low voltage shutoff circuit is not working...
I did not connect the diode...You haven't answered the questions in post #106. If the motor gets reversed then the diode should NOT be connected across it.
Correct, That is how I did it...With cutoff ~2 shown above, connection to downstream circuits should be from the two terminals of R7 (the simulated load); NOT from between 'out' and the ground symbol.
Which capacitor???The added capacitor (post #98) might also be responsible for the non-latching behaviour.
I don't know; but in post #98 you said you had added one!Which capacitor?
I had taken it back off when it changed nothing...in post #98 you said you had added one!
I had no idea how hard I was straining to see until I changed it!!!BTW, glad you got rid of those invisible blue components.
Not surprising. Large loads often pull the supply voltage down.Also, every time I hook up a larger load, the board shuts off
That's an option. A momentary switch (button) would do it. But doesn't the 1meg resistor drain the cap (C2, cutoff #1) once the supply V1 has been removed from the circuit? C2 can't discharge if V1 is left connected.Do I just have to build in a manual reset switch to short the source & drain?
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!YYYYYYYYYYYYYEEEEEEEEEEEEEEEEEEESSSSSSSSSSSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!But doesn't the 1meg resistor drain the cap (C2, cutoff #1) once the supply V1 has been removed from the circuit? C2 can't discharge if V1 is left connected.
Is there a place to put a capacitor to delay the shutoff, so that when the voltage drops when I hook up a load, it would not shut off???Large loads often pull the supply voltage down.
Increasing the value of C2 (cutoff #1) or C1 (cut-off #2) should help.Is there not a place to put a capacitor to delay the shutoff
Not in LTSpice, when I actually built the circuit...Since you have LTspice, can you post your asc file where 'small' and 'slow' demonstrate the problem?
