I'm familiar with the DC-DC voltage boost circuit (SMPS or switch-mode power supply), and I understand why an inductor is used. By using a low voltage to create a magnetic field in the inductor windings, you get a high voltage back out when the field is allowed to collapse. Makes sense.
What I don't understand is why I've seen several DC-DC buck circuits, where Vout is less than Vin, with inductors. (The one on Wikipedia for example, and others.) Couldn't a capacitor be used instead? Whenever Vout falls below spec, start charging a cap. As Vout rises above spec, stop charging the cap. You'll get a little ripple, but surely less than an inductor produces?
I'm sure there's a good reason for using an inductor. I'm just curious what that reason is?
