dc motor driver
t_sanoop
i am doing a robotic project . i am using a dc motor which is having high power...i used uln2003 driver ic to connect to the motor.but i found the ic is getting heated....i had shorted 3 pins of ic inorder to get high current capacity.....if any of you know any current sink ic which is having 1-3Amp current capcity....hoping that i will get reply from you...
thanking you
sanoop
hai sanoop
Is it a stepper motor ?
Why are u using darlinton ics ?
I think the correct option is the h-bridge ics
L293 or L298.
L298s are right for the current. Heatsink the 298, about 4"x4"
Heat is going to be your enemy here. You should get a tight handle on the current draw of the motor.
The L293 won't deliver the current you need. the L298 will do it though the limit appears to be 3A - right at your limit. that's a little troublesome. neither package (multiwatt or powerso) are super easy to prototype with. with 3A of current, the L298 will dissipate a very large amount of heat Vsat at 2A is 4.9V - that's 9.8W. Take it up to 3A and it's going to around 15W. I suspect you can get by with passive cooling (heatsink) for 1A draw but 2 or 3A draw will probably need forced air.
alternatively, you could build an h-bridge with mosfets. Mosfets with a reasonably low Rds will give you significantly lower heat dissipation. For example, mosfets with an Rds of .1 ohms will dissipate about a watt each at 3A. It would probably get by with a smallish heatsink. Plenty of plans on the web.
Phil
