I can send a picture of the circuit if it's easier.
That is actually perfect for what I need - thank you. It has a minimum output of 1.25V which is fine and I can limit the output by using 2 resistors.
Thanks!
I second that.Please do. Also indicate what will be connected to the voltage limited output.
The point marked "12V" on the circuit is what I was calling the reference voltage, and yes, the voltage at that point sets the maximum output voltage.digby_ice said:Hi,
I have read your reply a few times today. Would that circuit be suited to go on the output of the 12V? Is that 12V reference what makes it limit the overall voltage to 12V?
Thanks again for your reply
