deduction of output voltage relation
4electros
in the circuit shown :
assume that reset switch is closed for t<0, then opened for t=0
it's needed to deduct the relation of output voltage vo(t) for t>=0
firstly i think i have to use superposition theorem.
Transient analysis is what you need to use, not superposition. Superpositions is when different frequency signals are in the same circuit and you analyze the circuit separately for each frequency.
For initial conditions (t<0) you assume that the switch has been closed for a very long time and so C1 is storing no charge. Then you do transient analysis.
concerning t<0 , i think that v-=v+=Vos nearly due op-amp characteristic A=infinity so v(t=0)=vos is to be after very long charge
anyway what would i do to apply transient analysis? where should i start?
"so Vos=IB1*R1"
No, if it were so, the solution would be trivial. You have to assume that IB1*R1 is not equal to Vos. But v+ and v- of the opamp do have to be equal. Where does the excess current go?
