sfttailpaul
Hello,
I am attempting to build a control circuit to operate (up to) 16 relays that are DPDT. The initial control would utilize one of the many available relay boards found on EBAY or similar site. These low V/A relay boards would be the "trigger" signal to operate high current contactors (operating 1K watt lighting from each NO & NC outputs). My theory is that the NC signal would be live to one bank of contactors (#1 thru #16) and then when the NO is activated, it would operate a second bank of contactors (#1 thru #16). Most of the "ready made" relay boards have provision for a trigger input and this is where I'm at a loss. I simply cannot find a means to have this trigger sent to (up to) 16 different delays. The delay would hopefully, be adjustable but each separate delay would be the same, IE, relay #1 is delayed "on" by 90 seconds, relay #2 is delayed 180 seconds (the same 90 second delay), relay #3 is delayed 270 seconds (again the same 90 second delay), and so on, all the way to relay #16, the final 90 seconds would have had a total of 16 X 90 sec. = 24 minutes from the initial signal to the final one. The signal needs to operate 16 different outputs, each 90 seconds apart. The "adjustable" would change the "common delay" that could be from 30 seconds to 3-5 minutes. Very flexible with the common delay times but the need for up to 16 different control signals is the key here. There would be a master timer which would turn "ON" for a specific period of time (ultimately would be energizing all the NO relays) and then when it was "OFF" all of the NC terminals would be energized. The point I am trying to get at is a soft start for this high energy resistive lighting (show effects) with a "flip" effect so that the ballasts are always on and operating either the NO bank or the NC bank for a total of 32 single contactors...
Can anyone on here help me? I don't have money to pay someone BUT I do have lots of things to barter with in payment for someone's time and expertise. Please, if anyone can help me with this design, I would be forever grateful. This is a project for myself that can also lead to building several more of these control units. Once I can do the 16 different signals (or more even better), I could simply use what I needed to do smaller versions like 4/8/12, etc...
