The CD4047 IC can probably drive the Mosfets directly without the opamps.
The Mosfets need 100 ohm resistors in series with their gates to prevent VHF oscillation and the resistors must be mounted very close to the gate pins.
Which part number Mosfets did you get?
Voltage regulation is very complicated. You must rectify and filter the output to be used as a reference. Then you must make a complicated Pulse-Width-Modulation oscillator circuit that has the pulse width controlled by the amount of reference voltage.
The transformer voltage must be selected to be too high so that the PWM can reduce and regulate it.
A protection circuit must detect, rectify and filter the output current then shut down the oscillator if the current is too high. It might react too slowly then the circuit will blow up.
