Detecting 60hz AC Current?
haxor12
I'd like to build a handheld device which can detect a 60hz AC wire inside of a wall. Any advice/tips on how to do this would be much, much appreciated.
Thanks!
Go to Home Depot and lay about $10 on the counter. They sell a "stud finder" which includes the 60Hz detector...
What? So expensive?
They're 1.5 EURO in Germany (US$2.00)!
What? So expensive?
Yeah, I bought mine about 10 years ago while they were made in the USA. The one that they sell today is made in CHINA.
Thanks for the tips, I was most interested in learning to build one myself :)
Get a small audio transformer. Chisel off the bar on one side of the core to leave an open E.
Hook it to an ic amplifier (opamp or audio amp) with a gain of several hundred, gain optimized at 60 Hz.
Hook it to headphones and/or a meter-rectifier detector circuit.
There are many ways to skin a cat.
Modify a transformer as Mike suggests, or use a linear output Hall efect sensor.
You can also use a 4017 ic.
wire up to 9 volt battery
Leave input (14) open circuit,
Put 15 cm wire on it as areal.
connect one led to one of the outputs and loop o/p 10 to 1.
The led will flicker at 1/10 of the frequency.
I see if I can find schema for it.
