Digital Circuits
ad353
What is the easiest way to see if a circuit is digital when looking at a cicuit diagram?
what would it have?
IC's??
Adam
Well, its not always easy to tell. Remember that digital circuits are designed for either on or off . . . not a varying signal. I don't really know of any general rule. Most of the time, a digital circuit will have an IC, but analog circuits also are known to have IC's. Digital circuits can be very simple. Hope this helped a little.
Yes, that's pretty much it, digital circuits are built to have only 2 states, on and off , 0 and 1. No analog signals like varying voltages...
Both analog and digital can coexist on 1 circuit of course, so a circuit isnt always analog or digital, it can be a mix of both
One thing I look for is the voltage in the circuit, specifically around the IC's. If the voltage is about 5vdc then you can make a pretty good guess that the circuit is digital. Of course, this is not absolute because some analog circuits work off of 5 vdc. But, since a lot of digital circuits work off of 5vdc, its a good starting point.
Another approach is to simply research the IC's used in the circuit. You can look up the IC datasheet and the datasheet will almost always tell you if the IC is digital or not. If the datasheet does not tell you, then look at the Vcc voltage input of the IC. If the VCC is around 5 volts, then again, you can make a pretty good guess that the circuit is digital.
Of course, as Exo explained, most (all?) digitally oriented circuits are a combination of digital and analog. So, some points may work digitally, and others by analog.
In conclusion: Your best bet is to look at the IC's and see if the IC's are digital by looking at the datasheet.
