Wife put a package of strawberry's on the digital scale and it leaked juice down inside. Scales no longer worked. I took the case apart and the only thing inside is an aluminum strain gauge, circuit board and 3 rubber push buttons. It looks like the juice ran down into the on/off switch. I ran clean tap water through the switch then let it dry for 3 weeks. The scales will not work. How are these rubber push buttons made they appear to work like a keyboard? Am I wasting my time or will this switch work again?
The plastic case is glued together really good I will have to cut it apart with a hacksaw. I am sure I can unsolder the wires on the switch then attach them to a different try push button switch. A jumper wire across the switch should turn the scale on if I could only get to the contacts. Am I wasting my time or what?
