shashi.lahade
My M.Tech project is "Design of digital triggering circuit for 1 phase converter" I am making use of ATmega 32 controller, i have design the code which makes use of analog voltage 0-5 V, convert it with the help of ADC to 0-1023 counts. This count is use to decide the firing angle to trigger the thyristor. By varing voltage firing angle will vary. For 1 phase the code is ready, i have check tigger pulse waveform on DSO.
At the port of ATmega 32 the trigger pulse which is obtain, is 0.5 V and 100 mA.This pulse is not sufficient to trigger the thyristor, So i have use MOC 3021 which is an optocoupler driver IC for the same.
Please tell me which thyristor should i use for it. I have use BT 169,TYN 616 but i dont found the specific results.
please help me..
I have attach MOC 3021, BT169, BT 152 and TYN 616 datasheets.
MOC3021.pdfTYN616.pdfBT169D.pdfBT152.pdf
please help me..
