I bought an LED matrix alarm clock, which has about 30 white LEDs. The clock has three brightness settings - high, medium and dim.
I found that even on the dimmest setting, the clock still gives out a lot of light, so I opened it up to have a look inside.
Basically the LEDs are strobed in rows (as you would expect). However, on the medium setting, two 1N5817 diodes are brought in series with the LEDs, and on dim mode four 1N5817 diodes are put in series.
To lower the brightness further, I decided to add another diode to each string - thus medium would be 3 diodes, and dim would be 6 diodes.
Measured with a Fluke 87v, the Vf of the 1N5817 diodes is 0.57v. I had some 1N5819s in my parts box, and these measured 0.12v (surprising!). I therefore just stuck in some 1N4001s I had lying about.
Obviously (when you see the If/Vf graph), the 1N4001s Vf changes massively with VI, so all the rows are different brightnesses. Not great.
Should I just buy some more 1N5817s? Or is there something better I can use? The stock 1N5817s do have some difference between row brightnesses, but it isn't as bad as the 1N4001s. Any ideas?
Andrew
Andrew
