Direct Digital Synthesis (DDS) Simulation
Kerim
When I heard of DDS a few years ago, I had the idea to simulate its basic configuration.
I started from a work found in the archive of LTspice group (now, at groups.io). It was done by Mr. Helmut Sennewald.
I updated his work as I see it practical for my need.
I did the version which is attached here (DirectDigitalSinewaveGenerator_DDS_v2 .zip) to see how I could build an audio sinewave generator by using DDS. Please note that most values of the generated frequencies are average ones, due to DDS frequency jitter.
It seems that it could be done by using an 8-bit R2R ladder and a low pass filter (acts as a buffer too). The LPF here is of 3rd order, but perhaps the 2nd order is enough for the three audio bands below:
Band_1: 40.69 to 325.52 Hz, DDS loop= 768 cycles, 2^7 =< step =< 2^10
Band_2: 325.52 to 2604.17 Hz, DDS loop = 96 cycles, 2^7 =< step =< 2^10
Band_2: 2604.17 to 20833.33 Hz, DDS loop = 12 cycles, 2^7 =< step =< 2^10
Obviously, the R2R ladder is ideal in this simulation. So to implement it in real, the ladder’s resistors should be selected to have the same resistance as possible, their exact value (here, close to 39K) is not important.
Please note that the project here is for applications that are not disturbed by the frequency jitter.
Kerim
stepACCUF_xtlcyclesF_sampleT_sampleF_sine
##Hz#HzsecHz
102465536160000001213333337.5E-0720833.33
51265536160000001213333337.5E-0710416.67
25665536160000001213333337.5E-075208.333
12865536160000001213333337.5E-072604.167
1024655361600000096166666.70.0000062604.167
512655361600000096166666.70.0000061302.083
256655361600000096166666.70.000006651.0417
128655361600000096166666.70.000006325.5208
1024655361600000076820833.330.000048325.5208
512655361600000076820833.330.000048162.7604
256655361600000076820833.330.00004881.38021
128655361600000076820833.330.00004840.6901
I forgot to add the DDS loop which is related to the above simulation.
It is an example code written for ATmega8 in assembly language:
; DDS, with frequency jitter [12,96 and 768-cycle loop]
DDS_asm:
; ACCU_L= lower register of ACCU
    CLR   ACCU_L
; sineAddr= start address of sine table in SRAM
          = 0x??00 [table size 256 bytes]
; init XL at start address of sine table in SRAM [0x00]
    LDI   XL,  low(sineAddr)
; XH == high address of SRAM sine table [0x??,  constant]
    LDI   XH, high(sineAddr)
 DDSloop:
; step_H\L [16-bit]
; average F_sine= F_sample/(ACCU/step_H\L)
; no jitter if step_H\L is 2^integer
; or
; step_H\L= int(F_sine*T_sample*ACCU+0.5)
; ACCU= ACCU_H:ACCU_L = XL:ACCU_L
    ADD   ACCU_L, step_L        ; 1abc
    ADC   ACCU_H, step_H        ; 1abc
; Test band_idx (a high register, 0=band_3, 1=band_2, 2=band_1)
    TST   band_Idx              ; 1abc
    BREQ  DOband3               ; 2a/1bc , [5a,4bc]
    CPI   band_Idx, 1           ; 1bc
    BREQ  DOband2               ; 2b/1c  , [+3b,+2c]
DOband3:
    LDI   delayCntr, 224        ; 1c
band3Lp:
; 1+(224-1)*3+1 = 671
    DEC   delayCntr             ; 1c
    BRNE  band3Lp               ; 2c/1c , [+671c]
DOband2:
    NOP                         ; 1bc
    LDI   delayCntr, 28         ; 1bc
band2Lp:
; 2+(28-1)*3+1 = 85
    DEC   delayCntr             ; 1bc
    BRNE  band2Lp               ; 2bc/1bc , [+84bc]
DOband3:
    NOP                         ; 1abc
    NOP                         ; 1abc
; read sample from SRAM table [at XH:XL, XH fixed]]
    LD    sineSmpl, X           ; 2abc
    OUT   PORTB, sineSmpl       ; 1abc
    RJMP  DDSloop               ; 2abc , [+7abc]
; loop cycles: 12a,96b,768c
