Mosaic
Hi All:
I am designing a DC electronic load (perhaps up to 4A @ 30VDC) and I hope to add Constant current, Voltage & Power via a data logging uC approach.
4A = 16W dissipation via a 1 ohm , current sense, load resistance. Perhaps 5 parallel 5W wirewound, 1 ohm units used here.
A half amp 'low' range with a 10 ohm 5 W wire-wound load as a current sense => 10mV per mA for op amp amplification to feed the uC ADC.
Also with a resettable minimum voltage trip off and external cmos logic start & stop load triggers.
I hope to use it for general PSU design load testing and battery mAh profiling.
I want mA accuracy in the half amp range, which means a decent low offset, precision , current sense, op amp. I am open to suggestions please.
I did locate this one:
https://www.jameco.com/Jameco/Products/ProdDS/904798.pdf
@ a tiny 1 uV typical input offset, but only 2.7V - 5.5V supply
and this one ..about 60uV to 90 uV (grade C) typical input offset with a 5V - 15V supply.
https://www.jameco.com/Jameco/Products/ProdDS/239169.pdf
With a 10mV / mA signal does the LT1013CP seem adequate to feed the uC ADC an amplified current sense V?
It's about half the price of the 1uV offset OPA.
