Allacra
Hello everyone I am making my first electronics project. (attached below)
Here are the components:
74LS90 counter
74LS47 BCD to 7-segment decoder/driver
7-segment display
Toggle switch (reset)
IR emitter and collector/detector
The switch represents the doorway. When the swith is closed, no one is in the doorway. When the switch is open, someone is walking through the doorway (blocking the voltage). I want the counter(s) to recognize the change in Voltage (when the switch goes from open to closed), it should count. The switch will begin in the closed position. The way I have it set up, it is NOT working :-(
In reality, I will have an infrared emitter and collector. When someone blocks the IR light and the collector does not detect it, then the person moves and IR light is detected again, I want it to count.
The toggle button is supposed to allow me to reset once the display reaches 99 (its maximum). It does not matter what I do to the toggle, as long as the voltage switch is closed, the counter counts. As it is, the display is only reaching 08 and is automatically resetting itself (a 0 - 8 loop).
Can anyone help me??
Thank you!
Sharon
74LS90 counter
7-segment display
Thank you!
Sharon
