Ive always made single sided PCB boards and for my final yr project, i want to utilise a doube sided board, with a ground plane on the 1 side.
In the past ive had a couple of links on my board which doesnt look or shows poor design (even though its the best layout on a single sided board, but i have no idea how you would go about constructing a board like this...
my 1st query is can you have DIP components on a double sided board? is it a case of wiring the GND pin to the bottom plane and on the top plane, it looks as if its not connected?
what iff i wanted to traverse a signal across the top plane, and then to the bottom, how would i do that?
is double sided board MOSTLY good for SMT components?
Any help or website that explain it, as i cant find any good sites on it..
