DS1820 binary
What don't you understand? It's just BCD numbers.
Edit, 75 would be 150 converted to BCD, so 0x96.
does it mean
if 1111 1111 = -
and 0000 0000 = +
if yes
then what is 110 c ?
hi TT,
Think about it.:)
the least significant BIT is equal to 0.5C
So 110C = 220decimal which equals hex.........................??????
You need to understand 2's compliment numbers.
In 2's comp the leftmost bit is assumed to be negative.
All other bits are positive.
In a 4 bit binary number the bit values are
8 4 2 1
if we choose 2's comp representation they are
-8 4 2 1
So a decimal 1 would be
0001
and a decimal -1 is
11111
because -8 +4 +2 +1 = -1 (we just added the bit values where we had a 1)
a decimal -4 would be
1100
because -8 +4 = -4
Regardless of the number of bits it is always the leftmost bit that is assumed to be negative.
But as Eric said in the case of this sensor the rightmost bit is worth .5 rather then 1
