eagle cad pcb help
aruna1
Hi I designed and routed a custom PIC board based on 18F452.
before printing on a transparent sheet i printed it on a A4 sheet,but distance between pins are smaller than actual size of the PIC.that is i cant place 18F452 on pads of footprint,foot print is smaller than actual 18F452.
since i don't have a printer i first printed it with adobe printer to a pdf file and then printed it to a paper at my friends place,i didn't do any resizing on pdf file.i just printed it with actual size.
can someone help me with this?
i have attached all relevant files here
  • sch and brd files.zip
  • 18F452..pdf
Hi aruna1,
I suggest to install Eagle at your friend's PC and print PCB layouts directly from Eagle.
Even scaling a PDF file it will just be accurate for one axis since you can't use different scale factors for X and Y.
Your schematic is extemely hard to read because you drew nets through ICs. Addionally it looks ugly.
Is the power consumption of the PIC you're using somewhere in the KW range? A trace width of 1.016mm is really not necessary.
I reworked your PCB layout. It was too large to modify as the size restriction is 100X80mm for the free (light) version.
Don't use 90 degree bends when routing since they will cause problems when etching the board. I omitted 45 and 135degree angles at T-junctions which I recommend to draw there.
Boncuk
  • 18F452-I..zip
