BeeBop said:Design Rules -> Restring should do it, I think.
Faster - Wider - Deeper -SMALLER?
3v0 said:I have my grid set to .25mm and alt .125 mm.
When I do a change diameter and select a number smaller then .8 the diameter does not change.
However the if I do the same for width I can create small lines.
How can I make small pads ?
Was attempting to layout an adaptor board to go from .5 mm to .1 inch spacing. The plan was to just drop the pads and connect them.[LEFT said:justDIY[/left]]are you trying to build a package in a library, or just draw raw pads on a layout?
justDIY said:I bought a heavy duty magnifier off a popular online auction site, it's all steel with a steel mounting base. 22watt fluorescent bulb. works great for smd!
eagle will warn you when you're in error, sort of... check out the DRC button and all the options in there.
About feel out of my chair, good one.BeeBop said:...The whole reason I'm trying this is your fault, 3v0 - if you hadn't gotten me onto the processes I'm using now, my boards wouldn't be as good, and I'd have never tried...
