Eagle Noobie: Putting an LM34 into a schematic/layout
MikeMl
Most Helpful Member
I cant find an **broken link removed**/35 in the library. I'm using the TO92 version. How do I create a schematic symbol with pins A,K and R which matches the physical pins on the TO92?
Oops, just realized the sparkfun part is an S08 package. You should snag the sparkfun library anyways as it has a lot of other parts that you may want. You could use the LM34 part from the spark library and modify it for TO-92. I have only created a couple of parts with Eagle but when I made my symbols I used this tutorial.
Hi Mike,
here is the LM35 with a TO-92 package.
It was created using Eagle version 3.55.
If a part value is not displayed when switching to "package" insert the part value.
Regards
Boncuk
  • LM35.zip
Hi Mike,
Regards
Boncuk
Boncuk, have you ever considered offering a Eagle service as a source of income? You could offer symbol librarian services all the way up to full on CAD. I see this working for you...:)
No, I haven't.
Occasional component design is certainly not good enough to feed a family - and of course I won't charge for small work here in the forum.
I have developed special techniques which make it easy for me to design complicated packages (e.g. SOT227) within short time.
Regards
Boncuk
