Eagle polygon + ratsnest help
wakoko79
[SOLVED]Eagle polygon + ratsnest help
My problem is about ground planes.
I know how to do a ground plane or any signal plane.. my problem is described in the picture.
see the pad(green) and the trace? Well I did a polygon here to fill a signal trace, it is good besides the fact that THE RATSNEST DON'T COMPLETELY COVER THE PAD.
See, there are instead 4 or 5 lines from the signal connecting to the center of the pad. Because of that, there are gaps between the signal trace and the pad and the gaps are visible after printing... What I usually do is to darken it with a marker.. But now, I'm fed up. I want to know the real solution.
I want to fill those gaps.. anyway to do it?
thanks=)
(sorry, I forgot the picture =))
You didn't attach a picture so I'm going to have to guess.
I would assume you are looking at thermals, which are essential if you want to solder to the pad. Without those lines you'd need to heat up the whole plane before you can properly solder to the pad.
If you don't need to solder then you can turn thermals off.
Thankss!!!!!!
