As I mentioned in the OP, I simply added an extra resistor in the feedback network - and I posted the details on Banggood - however, I can't find them now. But it was obvious and trivial to do.
Whilst looking I found this post:
The PSU uses a common TL431 voltage reference chip, with a two resistor divider from the output - the top resistor (R18) is 203 (20K) and the lower one (R19) is 2321 (2.32K). The top end of R18 connects across to R20, and from there to the output - so I cut the track between R18 and R20, and added an extra resistor in there - according to ohms law an extra 5.6K should give you a reasonable 30V. There was enough room to add a standard through hole resistor between R18 and R20.
Good product, works fine, I have removed resistor R19 2,32kE and repaced it with potentiometer 1kE and resistor 2kE in series so the output voltage is adjustable between 19,5V and 27,5V becouse I need 21V output.
