sapphire_blue
I am using AD620 instrumentation Amplifier to amplify the ECG signal. Here's the datasheet.
I am still in the initial stages of the signal acquisition process. Right now, I am trying to see if the AD620 can amplify the signal with a Gain of 13.4 approximately. I used a 3.98K Ohm resistor to get this gain.
However, I am not using electrodes to get the signal. I am just using a function generator to give me a sinusoidal signal at 70Hz and 50 mV pk-pk amplitude. I connected the positive end of the function generator to pin 3 of the amplifier and ground to pin 2.
I expect the pk-pk voltage to go up by a factor of 13.4 but I do not see a sinusoidal signal on the oscilloscope. I just see a DC output. Could someone tell me why this is happenning?
Thanks!
Thanks!
