EEPROM doesn't return right value after shutoff.
The EECON1,WR bit doesn't clear in sim.
And it doesn't set in debug or release mode, when I reach "bsf EECON1,WR" in the write sequence...???
these are mine read/writes
get_epp_val
    movlw 2h
    movwf EEADR
    bsf status, 5         ; bank1
    bsf EECON1, 0       ; read
    bcf status, 5         ; bank0
    movf EEDATA, w    ; w = val from adr 2h
    retlw 0
write_epp_val
    movlw 2h
    movwf EEADR     ; EEADR = 2h
    movlw 77h
    movwf EEDATA   ; EEDATA = 77h
    bcf intcon, 7   ; int off
    bsf EECON1, 2    ; enable write
    movlw 55h
    movwf EECON2
    movlw 0AAh
    movwf EECON2
    bsf EECON1, 1    ; write NOW  77h @adr 2h
    bsf INTCON, 7    ; int on
    retlw 0
    call get_epp_val
or
    call write_epp_val
always works.....i've also noticed it helps to put some delay after write
not 1 or 2 instructions but something like 10microseconds, but that could be cause i'm still using old pics
I'm still not getting a value in EEPROM to write, the WR bit doesn't clear in Sim. I had to include a banksel command to get the value to go from NEW to EEDATA, otherwise it doesn't go to the register.
Could it be because of the banksel commands, that I should use BSF status commands instead?
Here's what I did with it:
	LIST	p=16F88
	include "P16F88.inc"
__config _CONFIG1, _WDT_OFF & _INTRC_IO & _MCLR_ON & _LVP_OFF
 errorlevel	-302
	Cblock	0x20
	 OLD,NEW
	endc
	banksel	TRISA		;bank 1
	movlw	0x42		;1MHz clock
	movwf	OSCCON
 	goto	start
read
    banksel        EEADR
    movlw           2h
    movwf          EEADR
    bsf               STATUS, 5         ; bank1
    bcf               STATUS, 5         ; bank0
    return
write
    movlw           2h
    movfw            NEW
    banksel          EEDATA
    movwf            EEDATA
    banksel          EECON1
    bcf                 INTCON, 7   ; int off
    movlw            55h
    movwf            EECON2
    movlw            0AAh
    movwf            EECON2
    return
start
	call	read
	banksel	OLD
	movwf	OLD
	incf	OLD,f
	movfw	OLD
	movwf	NEW
	call	write
	call read
 	goto start
	end
I just tried it all over the place, it still doesn't work in sim or in debug.
Now this is a stubborn bug. Has to be the last one. Everything else works.
I'll try slowing down the clock.
I think I found what the problem is...
write protect must be set in the config files, I have to find where the data is for config files...
getting there...
